114 oct
Old 07-25-2010, 05:08 PM
mikemunoz's Avatar
Default 114 oct
Going to the track for the first time. Was wondering is it worth putting racing gas 114oct in my car mixed with 93oct. Can anyone tell me there results before and after in the 1/4mile. Any info will help thanks.
Old 07-25-2010, 09:25 PM
Ph.D. in HUBRIS
custm2500's Avatar
If you don't change you tune then you will be waisting your money. I doubt you could tune anything better with 114 mixed if you are already tuned for 93.
Also if your car isn't majorly modified again you will be wasting your money.
Old 07-25-2010, 10:20 PM
mikemunoz's Avatar
mods r in my signature
Old 07-27-2010, 10:42 AM
6 & 8 Second Club
mrdragster1970's Avatar
Way too weak to need 114.
As mentioned, all you will do is slow the burn down in an engine that doesn't have the power to need it.
Old 07-27-2010, 11:17 AM
thunderstruck507's Avatar
unless you have knock retard it would be more likely to slow you down
Old 07-28-2010, 08:04 PM
chrs1313's Avatar
you need unleaded or you might take out the o2s...highest I have seen is 108 unleaded
but no reason for anything over 93 without a tune adjustment and even then you might not gain much
