Manual 6spd trans
Manual 6spd trans
my goat has been acting up since i intalled the new clutch (SPEC stage2 with steel flywheel), its hard to shift into any gear and makes me miss shifts if going at high speed anyone have any idea of what i can do to fix this?
Some aftermarket clutches can be picky.
Generally, I would look into if you used Specs shim or not.
Also, how well is the clutch bled.?
ANY air int he system and you may have dis-engagement / shifting issues.
So.... if everything was done correctly as far as mechanical assy and cleanliness, then I would look at the 2 above ideas.
Also, get in touch with Spec. They are on here quite a bit in the Manual trans forum and they are both helpful and responsive..
Good luck.
--Glenn
Good luck.
--Glenn
I'm not a huge fan of Spec clutches, they seam to be hit or miss. I would agree about bleeding the hell out of the system though. Did you replace the slave cyl when you did the clutch?
