Gauge needles jump at start up.
Old 07-25-2010, 06:45 PM
Slash8915's Avatar
Default Gauge needles jump at start up.
So starting this morning, every time I start up my car, my gauge needles jump all the way to the right, then slowly go back down to the left, then go where they are supposed to. I also noticed that my miles driven keeps resetting itself to 0. Any ideas?
Old 07-25-2010, 06:50 PM
redta99's Avatar
Time for a new battery, mine was doing this, replaced the battery over a year ago and hasn't happened since
Old 07-25-2010, 07:05 PM
Slash8915's Avatar
I just replaced the old one with an expensive *** optima a few weeks ago...
Old 07-25-2010, 07:09 PM
redta99's Avatar
Could have a bad cell, thats what was wrong with mine, couldn't tell because it seemed to start fine, then about a month later it sounded weak, tested it, and said bad cell. It never hurts to have it tested, mine's an interstate megatron, not that it matters that they're both interstate, but mine was doing everything your describing.
Old 07-25-2010, 08:14 PM
Slash8915's Avatar
it's not doing it anymore... weird...
Old 07-25-2010, 08:53 PM
GR8RYD's Avatar
Mine showed exactly those symptoms, and then they would go away, and then return. One morning, nothing. The engine would not even attempt to turn over. Put a new battery in and have not seen the symptoms again.
Old 07-25-2010, 08:55 PM
Slash8915's Avatar
Well I have an Interstate Megatron II on standby, just incase. How do I go about getting a new one under the warranty?
Old 07-25-2010, 09:23 PM
redta99's Avatar
You shouldn't have a single issue with warranty since you just bought it, take it back to where you purchased it, and tell them what's going on, if you wanna be sure take it to any local parts store that tests batteries and ask for a print out, then if it is in fact a bad cell etc, return it.
Old 07-25-2010, 11:50 PM
bigfatls6's Avatar
Make sure your ground cable is tight and both are makeing good contact.
DarknessHunter's Avatar
had same issue mine was just bad ground from battery up to frame the lil wire that comes off ground
Old 07-25-2010, 11:52 PM
kmdracer's Avatar
Beyond doubt it's a battery problem. I've had this several times in my 99Z (I've owned it since 2000, so have put a few batteries in it)
Old 07-26-2010, 01:09 AM
Super-Bat's Avatar
Bouncing gauge needles = alternator problem.
New battery going bad prematurely = alternator problem.
I'd check your alternator, and the wires coming from it.
Old 07-26-2010, 08:00 AM
TWS
TWS's Avatar
This is a well known issue with '99 model year F-bods. My '99 did it too, whenever my battery wasn't in absolute tip top shape. Do a search and you'll find several threads about it that are a few years old.
Old 07-26-2010, 08:35 AM
Slash8915's Avatar
It better NOT be my alternator! I just had THAT replaced a few months ago, along with my starter!
