Starter Grinding on new TCI flexplate.. helppp
Old 07-26-2010, 05:35 PM
Dragkid1917's Avatar
Default Starter Grinding on new TCI flexplate.. helppp
So, i just bolted everything together and started to turn the motor over with the coil packs unconnected. Afer a few seconds i hear a terrible clunk clunk clunk. After going down there I see my new TCI Flywheel has some pretty serious wear marks. The new starter was using actually cracked around the mounts because of how violent it must have been shaking. Has anyone had this problem, is it an alighnment issue or could I have a flywheel with the wrong amount of teeth? Im using my old starter again and the same problem happened again but I didnt leave it on long enough to cause damage. Any help at all in this matter would be gggggreatly appreciated.
Old 07-27-2010, 10:36 AM
kevin87turbot's Avatar
Is it a standard LS1 crank? I've seen this on an early model 6.0L crank before, but not a standard LS1...
Old 07-27-2010, 02:52 PM
yhea stock crank... im so confused.
Old 07-27-2010, 05:05 PM
forcd ind's Avatar
what is the flywheel #
Old 07-27-2010, 06:18 PM
Its the 98-02 TCI Flexplate, TCI 399753 is the number from the ws6 store.
http://www.ws6project.com/user_stor/...oducts_id=1233
Thats the direct link, what were you thinking could be wrong?
Old 07-27-2010, 08:53 PM
Can you post a pic of the flexplate and how it's installed?
Old 07-28-2010, 06:59 AM
forcd ind's Avatar
a pick would be good, make sure its not backwards or something-take a meas from the back of the engine, where the bellhousing hits, to the back side of the flywheel teeth (engine side)
i think that flywheel has a small spacer on it, should be toward the engine
Old 07-28-2010, 05:23 PM
ok will do, im at school right now on friday ill drive back to NJ and get some pics for you guys. Thanks for the help.
Quick Reply: Starter Grinding on new TCI flexplate.. helppp
