impact of too short pushrods?
Old 07-27-2010, 04:24 PM
merim123's Avatar
Default impact of too short pushrods?
I'm starting to wonder if my pushrods are too short in my engine. Would that cause me to look like I'm losing power on top (past 5500 and look like valve float?)
I have some 7.05's right now and have some 7.2's on the shelf. I was thinking of swapping them out on the #1 cylinder only, using a permanent marker and seeing how it compared if I let the engine run for a few revolutions. is there an easy way to test this without pulling the intake and using a solid lifter? I have a comp cams pushrod checker available.
thoughts?
Old 07-27-2010, 04:34 PM
RamAir95TA's Avatar
When pushrods are too short, they exert side thrust against the valve stem and valve guides, which can result in a bunch of bad stuff.
When you built your motor, did you check for proper pushrod length using an adjustable-length pushrod? Doesn't sound like it...
Old 07-27-2010, 05:03 PM
gregrob's Avatar
You would have to mill the **** out of the heads and deck to need one that short. I'm with Joe, doesnt sound like the builder checked it out properly.
Old 07-27-2010, 05:05 PM
RamAir95TA's Avatar
To put it into perspective, I have a zero-decked block and milled heads with 52cc chambers and my PRs are 7.10" in length, ever so slightly biasing the exhaust side.
Old 07-27-2010, 05:17 PM
merim123's Avatar
Is there a way I can check without a solid lifter, with the engine assembled?
Old 07-27-2010, 05:23 PM
RamAir95TA's Avatar
IMO, the only way to do it is with a solid lifter. I purchased one LS7 lifter just for this purpose. I took it apart, disassembled it, and reinstalled the plunger with a small wedge of metal to keep it completely "pumped up."
Old 07-27-2010, 06:52 PM
merim123's Avatar
i hear ya on the proper way, this all took a few years to come together, so it is what it is now.
on the first question i had, could a shorter pushrod look like valve float over 5500rpm?
Old 07-27-2010, 08:22 PM
merim123's Avatar
here's the valve tip with some sharpie testing real quick. this is with the 7.05...
i let it run for about 5-10 seconds so that that lifter would pump up
and here's the 7.2 pushrod...
here's the 7.05 from the side...
here's the 7.20 from the side...
notice how the 7.2 side shot looks like it hangs over the valve more toward the exhaust
Old 07-27-2010, 08:31 PM
speed_demon24's Avatar
What springs are you running and whats the installed height?
Old 07-27-2010, 08:44 PM
merim123's Avatar
if i recal, the 10308 (99893?)cranes they are 1.46 OD I think, i'd have to take it off and measure installed height. why do you ask about the installed height? coil bind?
they are setup for 180lbs on the seat according to the guy that did the heads.when I talked to him, he was pointing at the lifters instead of the springs.
Old 07-27-2010, 09:19 PM
If they are setup at 180lbs on the seat there's no way you're getting valve float with that cam. There's more of a chance of you collapsing the lifters with that pressure. And I hope you're running chromeoly pushrods with that much spring pressure.
Old 07-27-2010, 09:55 PM
merim123's Avatar
yup comp cam chromoly. i called the guy that did the heads, he was pointing at the lifters too. they are stock lifters with about 2500 miles on them.
Old 07-27-2010, 10:46 PM
BALLSS's Avatar
Crane 10308 spring is :
1.75" install height
165 lb seat
426 open @ 1.10"
...so if they are 180 on the seat maybe installer shimed them to 1.7x to bump up seat preasure to 180??
GM846 cam should work well with the 10308 springs
My $02 on the PR length is 7.05 based on pics.
stock lifters @ 2500 miles should be fine
while valve springs could cause you to nose over at higher RPM's I would look into ignition.
even if the springs are installed at 1.70 you won't hit coil bind with the 846.
Old 07-27-2010, 11:35 PM
165 lb seat
426 open @ 1.10"
There's no reason to have anywhere near 180lbs on the seat with that cam. That's approaching solid roller seat pressures.
Old 07-28-2010, 12:38 AM
merim123's Avatar
i'll take the spring off and measure to confirm. The guy that did the heads asked me to bring the springs by to test them out to see if they are still ok. I'm doing all this because of my other thread about the dyno tune and trying to address what is happening at 5500-6000 on my dyno chart. https://ls1tech.com/forums/lt1-lt4-m...-dynotune.html
Old 07-28-2010, 06:53 AM
wrd1972's Avatar
Everything has been said above. Imho, the 7.200 is giving a nice narrow sweep while being a tad offset toward the exhaust side. If you go shorter, the sweep will increase but the pattern will center up more. Imho, narrow sweep trumps a centered pattern.
Old 07-28-2010, 09:00 AM
merim123's Avatar
I hear you on the narrow sweep, it won't hurt to try, looks like a 7.1-7.15 might have been ideal.
Old 07-28-2010, 10:28 AM
Village Troll
SS RRR's Avatar
Stay with what you have. The sweep looks fine. Notice on the 7.2 the roller tip is not making full contact onto the valve tip.
Old 07-28-2010, 10:43 AM
Originally Posted by SS RRR
Those are the springs that have been recommended to use for the GM847. I have a crane in that profile and those are what they suggested I use as well. Most SR spring pressures are over 200lbs on the seat.
He has the gm846 not the 847. And you might want to look up what the word approaching means.
For the record i was running 7.2 pushrods with that cam and the same springs he is, but the installed height was around 1.8". My point was there is no way in hell he is getting valve float with that cam with 180# of seat pressure. Crane only calls for 125 for that cam jfyi.
Old 07-28-2010, 10:47 AM
Village Troll
SS RRR's Avatar
180lbs is far from "approaching" SR seat pressures. That's like still on the tarmac of the departure runway...
Quick Reply: impact of too short pushrods?
