arp head bolt torque specs
Old 07-28-2010, 08:45 AM
ElkySS's Avatar
Default arp head bolt torque specs
anyone know what they are on an afr head? (idk if that matters or not)
Old 07-28-2010, 10:33 AM
Village Troll
SS RRR's Avatar
It doesn't matter. You can see what ARP recommends on their website, but mostly anyone with ARP head bolts used on aluminum heads torque them between 65 to 70ft. lbs.
Old 07-28-2010, 11:37 AM
ElkySS's Avatar
couldnt find them on arps website. (mostly cause my phone sux) i found them on afrs website. it was 65-70 ft lbs. thnx
Old 07-28-2010, 07:39 PM
sbs
sbs's Avatar
Instructions come in the box.
From a recent set of 134-3601:
Old 07-28-2010, 08:01 PM
airfix's Avatar
My instructions said 3 steps to 70ft lbs.
Old 07-28-2010, 08:03 PM
LT1John's Avatar
dont mean to jack the thread but are the head gaskets side specific? i know that they can be upside down but does matter what side?
Old 07-28-2010, 08:15 PM
airfix's Avatar
Ussually its embossed side up.
Old 07-28-2010, 08:16 PM
Wicked94Z's Avatar
no doesn't matter, heads can be reversed as well, just gotta switch the steam pipe plugs on the heads.
Old 07-28-2010, 08:19 PM
airfix's Avatar
Thats what I thought but wasnt sure if it applied for all gaskets.
Old 07-28-2010, 08:33 PM
Wicked94Z's Avatar
i dunno my mr gasket MLS units have no up/down side, you can throw em on however you want. I wouldn't go more than about 70 ft lbs with 30wt on a stock block. an aftermarket block you can go up higher, **** some fast nitrous lsx guys were doing over 100 ft lbs on aftermarket 4 bolt blocks to keep the heads on em.
Old 07-28-2010, 10:23 PM
RamAir95TA's Avatar
Go with a 3-step torque sequence. 25#, then 45#, then 70#.
The following users liked this post:
NewOrleansLT1 (08-07-2021)
Old 07-28-2010, 11:20 PM
ElkySS's Avatar
i didnt buy the bolts. they came on the motor i bought.
Quick Reply: arp head bolt torque specs
