98-02 Convertible - 10.5" fit with no mods?
Old 07-28-2010, 04:28 PM
MJMZ28Cvt's Avatar
Default 98-02 Convertible - 10.5" fit with no mods?
I'm wondering if any of you are running 10.5" wide rims on the back of a convertible without mods. I'm thinking it won't fit. (Offset is +56mm)
Old 07-28-2010, 07:30 PM
Xsta Z 28's Avatar
Should be OK . . . I ran 57 mm . . . and had to do a very small amount of inner wheel well massaging . . .
Old 07-28-2010, 08:01 PM
MJMZ28Cvt's Avatar
Ok, thank you. Was that with any lowering?
Old 07-29-2010, 08:15 AM
Xsta Z 28's Avatar
Lowered about 1"
Old 07-29-2010, 08:48 PM
69TA's Avatar
I got some 10.5's for sale and they fit fine.
https://ls1tech.com/forums/parts-cla...295-tires.html
Old 07-29-2010, 10:18 PM
99'CajunFirehawk157's Avatar
17x11 No mods, No rubbing, NOT lowered.
Old 07-30-2010, 12:45 AM
MJMZ28Cvt's Avatar
Right now I have 18x9.5's, +56mm. If I understand correctly, if I switch to 18x10.5's, +56mm, the wheels will extend a half an inch further towards the inner wall?
....and wow that Firehawk is CLEAN
Old 07-30-2010, 09:47 AM
Xsta Z 28's Avatar
Yup. 1/2" further in and 1/2" further out.
Old 07-30-2010, 01:58 PM
tmdz28's Avatar
what's the difference between coupe and convert? I thought they are all the same? Sorry, i am a newb.
Old 07-31-2010, 03:31 PM
Xsta Z 28's Avatar
In the wheel well? . . nothing . . . under carriage there are additional stiffeners.
Old 08-03-2010, 04:20 PM
MJMZ28Cvt's Avatar
I know it would be preferable to go larger, but is it possible to run a 275 tire on a 10.5" rim?
Old 08-06-2010, 10:36 AM
gyrene2003's Avatar
dont run a 275, defeats the purpose and would be ugly as ****, im tellin u, ive seen it, it looks like the damn tire want s to come off the bead and its all narrow, like a pyramid, dont know how safe it is either. U would waste ur money gettin a wider wheel with stock size tires. Im runnin MT ET streets in 315/35/18 on mine out back, did alittle grinding of the bumpstops and some "massaging" of the fender wheel with a BFH!!! No prob, and i only have the hose mod.
On a side note: Cajun, what tires are those, im lookin to run a cheap *** street tire on mine now that im gettin bigs and littles for te track, are u runnin 17 or 18, they look like 18. Summitomos? How much they run? Im tired of payin 300 a tire when i blow them off after one track day. Want somethin cheaper than a radial, dont care if they roast easily.
Old 08-06-2010, 05:57 PM
pathology knight's Avatar
i've got a 2000 vert with no (suspension) mods and my 10.5 didn't fit. I got the z06 c6 from OEwheels with a 295/35/18 tire. they rubbed on my car.
i got a 1/4" spacer but haven't had a chance to mount them with the spacer yet. i might have to grind the bumpstop back too....but we'll see.
a smaller tire might have worked, but on a 10.5" rim a 275 is way to small. (see above comments). a 285 might work, but i don't know how common a size that is. the 295 fits great on the rim and looks killer. i didn't realize how big they actually were!
Old 08-06-2010, 08:45 PM
Thumbs up
Yep 17" 315 Sumos, been awhile but I think they were like $150 ea...
Sounds like you got the wrong off set, FWIW.
Old 08-06-2010, 08:49 PM
69TA's Avatar
with no suspension mods 295's fit fine with the spacer
don't bother with the bump stop unless you plan on doing jumps.......it only rubs when you jack the car up and let the suspension free hang
Old 08-06-2010, 09:14 PM
MJMZ28Cvt's Avatar
Ok, I finally had a chance to get under the car and see what was going on. The car is lowered with the SLP level 1 package. Right now I have a 9.5 inch rim, +56mm offset, 275/35 tires and they're already awfully close to the inner wall. The clearance between the tire and the part of the inner wall closest to the front of the car where it curves around is hardly anything right now. Is this is area people are banging in? Also, the bottom part of the tire is very close to the LCA's. I do not want to run a spacer. With the new rims at 10.5" and +56mm, they will extend inwards at least a half inch, depending on the tires. Thoughts?
Old 08-09-2010, 09:53 AM
Xsta Z 28's Avatar
Ok, I finally had a chance to get under the car and see what was going on. . . . The clearance between the tire and the part of the inner wall closest to the front of the car where it curves around is hardly anything right now. Is this is area people are banging in? . . .
Yep that is the area for some minor massaging with a BFH.
Like I said I ran 57 mm, w/o spacers, and 295/35R18 tires.
No issues with the LCA.
What I did was mounted the wheels and tires to the car. Gently drove the car around the block . . even up and down the driveway would be enough.
Jack up car, remove wheel & tire, saw where the tire rubbed the undercoat, and massaged the area.
Remount, and repeat until sound goes away.
I did center my axle with an adjustable panhard once the suspension lowered.
Old 08-09-2010, 12:22 PM
MJMZ28Cvt's Avatar
Thank you, your input has been very helpful. How much of a difference do you think the adj panhard makes?
Old 08-09-2010, 12:38 PM
^^^^x1 Registered User
FireTA98's Avatar
That's a very sexy hawk.
Old 08-10-2010, 10:42 AM
Xsta Z 28's Avatar
On stock suspension, not really needed, but would be required once you lower the car.
Quick Reply: 98-02 Convertible - 10.5" fit with no mods?
