94 Steering Column - What Years Work?
Old 07-28-2010, 09:20 PM
1997 Z71's Avatar
Default 94 Steering Column - What Years Work?
I need a steering column. What years are compatible for my 6 speed 1994 Firebird? From what I can find it looks as if 1993 to 1996 might be compatible. They all use the same part numbers for the turn signal and the ignition switch(manual or auto).
Any help appreciated.
Old 07-28-2010, 10:23 PM
nomoneyz's Avatar
Not sure what others will work, but I have one from a 76xxx mile 94 Formula.
Old 07-28-2010, 10:57 PM
Gojira94's Avatar
The VATS will be transferred with your ignition lock cylinder. The only other stuff in the column is: turn signal (no brainer, all the same); cruise control (if your car has it); airbag if you still have it. IIRC, no mechanical difference from 93-97.
Quick Reply: 94 Steering Column - What Years Work?
