tx02
07-29-2010, 08:49 AM
Ok so here is the deal, The truck is a 1999 ext cab short bed 2wd with 212k (any one that knows a cummins know's that is nothing). The truck is in amazing shape for 11 years old, there is only a few door dings and a few scrates on it. I have only had it for about two months and already sank over 3 grand into it. Im just tired of the diesel world for now (4th one) I was told of it having new wheel bearings, A new clutch and slave cyl and a few other small things. Clutch wise im not sure if its factory or an aftermarket one but it doesnt even feel like it would want to slip with every thing done to it. Sence I've owned it I have done every thing within the last 5K except the edge, clutch, and a few other things. It has non electic mirriors but Im guessing they used to be because it has the mirror defrost button on the a/c controls.
Exterior/ drive train / interior
-New ball joints upper and lower
-3" DROP shackles in the rear
-6000k Hid's fogs and head lights
-3rd gen rims
-New tail lights
-Refinished head lights
-36gal aux tank with pump in the bed
-Debadged with 06 model Cummins C badges
-Brand new dash
-Black diamond plate bed rail covers
-Black diamond plate Rearend replacement bumper
-Clearance lights
-Tow Mirriors
-Glow shift gauges (fuel psi, boost psi, egts)
-All windows tinted
-rubber floor (way better to keep clean)
Performance:
-Airdog 2
-Home made instake manifold
-S&B icebox cai
-150hp injectors
-5" exhaust with 4" dp and 6" tip
-HX-35 with boost elbow 35-40psi
-Edge comp
The only thing really wrong with it is it needs a new front bumper were it had a grill gaurd on it, Passanger rear door wont open from the inside handle, it has a rattle some were in the dash and the cluster bezzle has a crack in it. Truck is washed and cleaned twice a week and will be spot less on pick up.
The truck is located in Odessa TX 79762 and if you here to talk crap or tire kick go some were else I don't have time to deal with it or care to. I will respond to all offers.
-3rd gen rims
-New tail lights
-Brand new dash
-Clearance lights
-Tow Mirriors
-All windows tinted
Performance:
-Airdog 2
-S&B icebox cai
-150hp injectors
-Edge comp
