McLeod RST
Old 07-30-2010, 11:30 AM
edge04's Avatar
Default McLeod RST
I am looking to buy this clutch. Anyone know anybody running any specials on it or the best place to buy. I want it balanced so.
Thanks
Old 08-02-2010, 10:45 AM
edge04's Avatar
so should i just buy direct from McLeod?
Old 08-02-2010, 03:22 PM
Red99TA's Avatar
I got a good deal on it from Jesse at Scoggin Dickey. Definitely shop around for the best price. I had McLeod balance it as well.
Old 08-03-2010, 02:16 PM
LS1TECH Sponsor
Joey@Tick's Avatar
http://www.tick-performance.com/tick...utches/#mcleod
Old 08-05-2010, 06:04 PM
Billy M's Avatar
We try to support of dealer network the best we can. I suggest going to one of the many McLeod dealers that are sponsors on this site including Joey at Tick Performance. Hey Joey, Charlotte is right around the corner are you interested in that program we did back in March?
Old 08-06-2010, 08:14 AM
LS1TECH Sponsor
Joey@Tick's Avatar
Yes sir! I'll shoot you an email.
Old 08-06-2010, 12:01 PM
edge04's Avatar
I did order from Joey thanks.
Joey, this is back ordered right. I just saw a post where it took someone 7 months to get.
Old 08-06-2010, 01:28 PM
Billy M's Avatar
The RST is good in stock. It was the Original Street Twin for the LS that was back ordered so long because of the Master Cylinder issue.
Old 08-10-2010, 07:32 PM
edge04's Avatar
Got it! Wow its almost to nice to install!! Question, I am using my flywheel but I want to balance it to the PP but do I just bring the PP or also bring the adapter ring to the shop??
Old 08-10-2010, 09:02 PM
Red99TA's Avatar
You want to balance it as an assembly so bring your flywheel, adapter ring, floater, and pressure plate.
Old 08-10-2010, 10:13 PM
Billy M's Avatar
Make sure when you index the flywheel and pressure plate
After it's been balanced using either
The blue dycum marks we supplied on the unit
Or add some new marks before pulling the unit
Off the balancer. This way you'll know which way to
Re assemble the unit when it goes back on the motor.
Old 08-10-2010, 10:18 PM
edge04's Avatar
I am told that All the clutch parts should be zero balanced from the manufacturer...if you include them with your rotating assembly for balancing...you may be shooting yourself in the foot if the clutch isn't "perfect"...then you might end up out of balance down the road if you swap clutches. Any unbalance that is caused by the clutch components will most likely be negligible at worst (you'd never feel it and it won't have any effect on your engine). I did already have the flywheel resurfaced and balanced???? Oh and my entire engine assembly has been balanced as well.
Quick Reply: McLeod RST
