No Tcc with 4l80e
Old 07-30-2010, 11:54 AM
73 nova guy's Avatar
Default No Tcc with 4l80e
looking for some help. my car has a 5.3 with a 4l80e and i have no tcc lockup the trans works like normal in every other gear but no tcc. i am using efi live and with the commander the converter will lock up. but in normal driving mode it will not go into tcc mode. i need some idea's were to start figuring out this problem. i have went and turned off dtc's that i don't need the only dc's i have are p103/p103 maf codes being the car is speed density the codes are set to non emissions if i place them on not reported the car doesn't run correctly. and p0463 for a fuel level sensor. i cant for see these not allowing the tcc mode.
i have a brake switch signal to the pcm.
any ideas on were to look would be great..
Old 08-13-2010, 09:20 PM
02WHITEWS6's Avatar
I'm having same issues. Mine is a 4l60e with a yank 3600. When commanded the converter will lock, but not in its own. What is the problem or what to look for?
Old 08-14-2010, 11:38 AM
Gingervitis Addict
slow67's Avatar
Make sure your misfire tables are set correctly. An aftermarket converter with throw misfires (without a code) because it weighs less. If you can lock it up with the scanner, but the tune won't, this is most likely your issue. It happened to me.
Old 11-24-2010, 09:35 PM
johnnyfast's Avatar
I had same problem with 4l60e. I had to disconnect purple wire goin to brake switch.
Old 11-24-2010, 10:52 PM
garygnu's Avatar
the lock up solinoid could be bad or sticky.
Quick Reply: No Tcc with 4l80e
