4L60E Rebuilt w/Drive Problem
Old 07-30-2010, 04:26 PM
walkdmc's Avatar
Default 4L60E Rebuilt w/Drive Problem
I just finished a rebuild on a 4l60e. Reverse works, manual 1st works and manual 2nd works. No activity at all in Drive it’s the same as Neutral. I can get it up to speed and go into 3rd manually, but when I switch into Drive again nothing.
What are possible causes that could keep it from not engaging Drive?
My thoughts on possible causes:
I packed the check ***** with Transjel to keep them in place; will I need to let the transjel dissolve first, a check ball is out of place, a problem with a solenoid, or maybe a problem with the pressure switch.
Any help would be appreciated.
Old 07-30-2010, 05:35 PM
Jays_SSZ28's Avatar
Input sprag in backwards.
Old 08-02-2010, 01:09 AM
walkdmc's Avatar
Thanks Jays_SSZ28, it was the forward input sprag. I reversed it and everything is good.
