what posi or locker to go with for a daily driver??
Old 07-31-2010, 05:10 PM
ryanosborne's Avatar
Default what posi or locker to go with for a daily driver??
ive got a stock 94 firebird formula rear, the posi is worn and i need a new one or a locker. what would any of you recommend, cause its a DD and i want both tires to always hook. any of these any good to me? http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
also what else would i need to replace one?
Old 07-31-2010, 05:38 PM
RamAir95TA's Avatar
Eaton make a great 10-bolt positraction unit, arguably the best. I ran one forever until I upgraded to a 9". If you upgrade, it would be a terrific time to upgrade to a new gearset since the old one has to come out.
Old 07-31-2010, 07:32 PM
speed_demon24's Avatar
I broke the spider gears and sheared off the tabs on the clutch packs on my eaton. I'm running an auburn racers diff now. Whatever diff you go with don't expect it to last if its in a 10 bolt.
Old 07-31-2010, 10:48 PM
is this the one? http://www.summitracing.com/parts/ETN-19599-010/
what else would i need to replace this? any other parts i need?
Old 07-31-2010, 11:05 PM
RamAir95TA's Avatar
I would let whoever is rebuilding your rear decide which Eaton posi is right for you. Building a 10-bolt requires alot of parts, something that your drivetrain specialist will know.
Old 07-31-2010, 11:19 PM
is there a list of parts i would need anywhere just for a idea of what i will need? is there less parts i will need if i got a trutrac locker?
Old 07-31-2010, 11:25 PM
RamAir95TA's Avatar
Again, parts that your builder will order. You're going to need pinion bearings, crush sleeve, pinion nut, shims, carrier bearings, axle seals, etc. I am sure there are kits out there but it's best to let your builder take care of it, especially in your situation.
There's no such thing as a "Truetrac Locker." "Truetrac" is a limited slip differential (same as a posi).
Old 07-31-2010, 11:33 PM
i know what youmean but their arnt many experts here thats why i wouldlike to have the parts for the builder to use
Old 08-01-2010, 12:12 AM
If you're just changing diff's all you need are carrier bearings/races and shims. The other bearings/seals are optional. And I would only use timkens in the rear end.
Old 08-01-2010, 12:20 AM
where should i get these parts and im not sure what to get? a detroit locker or the posi
Old 08-01-2010, 12:51 AM
mrchyzy16's Avatar
I would go with the posi if you are dd the car. I heard that a locker isnt that great for a dd. I could be wrong tho so maybe someone else could back this up.
Old 08-01-2010, 01:06 AM
yea i heard the locker had alot of getting used to but im still not sure what im going to go with
Old 08-01-2010, 09:06 AM
meine96ws6's Avatar
Hey in this months issue of gm high tech they have an awesome write up to building up a 10 bolt.. it has the part numbers and everything..
Old 08-01-2010, 12:56 PM
do you have a link?
Old 08-01-2010, 01:29 PM
is this it http://gmhightechperformance.automot...aul/index.html
Old 08-01-2010, 07:51 PM
Unless they magically increase the size of the ring and pinion its a waste of $$.
Old 08-01-2010, 10:55 PM
well i cant get a whole new rear right now so im going to waste my money on a new posi or locker, i just cant decide what to get and what exactly i would need
Old 08-02-2010, 01:20 AM
brucer's Avatar
lockers will engage and disengage when you turn corners.. if its a cog type locker it is annoying and can push you through a turn, can also kick the rearend dangerously to the side in a turn.. they are hard to get use to, and can be dangerous as they are actually made to go in a straight line... never liked lockers myself..
they are annoying also, when they engage and disengage they make a somewhat loud pop..
a small upgrade from stock would be a stock ls1 limited slip unit..
i'm like a few others, i wouldnt spend the money on a 7.5 rearend.. maybe swap in better gears, use a solid crush sleeve, and possibly an aluminum cover, thats about as far as i would go with one..
because when it breaks, you could atleast sell the cover, and maybe the gears if they survive..
i've always used the ratech installation kits for 9inch and 8.8 fords never had any problem with them.. they usually come with all the seals and bearings, last i bought one they were around $100, i would get an extra shim kit just in case you need more shims or that certain shim you dont have.
Old 08-02-2010, 10:50 AM
what gears would you recommend?
Old 08-02-2010, 11:17 AM
RamAir95TA's Avatar
Automatic or 6-speed? What mods? What's it being built for?
Quick Reply: what posi or locker to go with for a daily driver??
