Datalog software for 96 obd II?
The '96 and '97 cars aren't well supported. MXScan was the most reasonable but that was recently pulled from the shelf.
ECMPro is an option. Found here: http://westers_garage.eidnet.org/scan_software.htm
I haven't used the software so I can't tell you if it's any good. It does seem a little pricey though. It will work with either the Tunercat or JET DST cables. I don't know if it will work with any others.
You also could use something like Autotap. I don't believe it will log MAF Frequency though (which may not matter to you).
Hope this helps!
Hope this helps!
