cubezilla
08-01-2010, 11:24 AM
Just bought a 6.2 L92 shortblock and need some advise on a easy transition. My truck is a regular cab c1500 w/a 5.3, Heres what i to know about???
Fuel injectors, can i use mine from my 5.3??
Reluctor wheel is a 58tooth and my truck is a 24tooth??? what to do???
Knock sensors in valley cover??? Leave them unplugged and tie up harness??
Plan on using a std timing chain and cover(deleting the VVT) any issues??? Should i use my cahedral 5.3heads and intake or will it kill the Power it makes And if i need to use the L92heads and intake i am assuming i can use my throttle body on a L92 intake or L76 intake since my truck is cable driven??? Im not trying to build a drag truck, the idea is my truck is payed for and i would like the torque and HP of the L92, it will make things easier when i am hauling my car to the drag strip.... And i have a 24tooth LS1 crank sitting in the corner, could i use it in the block if i need to change or is their an easier way??? OK GUYS I NEED HELP!!!!!
