my motor sounds like a sewing machine ...normal for an LS ?
Old 08-01-2010, 03:01 PM
Dickie-311's Avatar
Default my motor sounds like a sewing machine ...normal for an LS ?
my engine is a 03 6.0 lq4 w/ texas speed 2.5 ls6 heads (cut .010 ) and there
T3 cam , LS7 lifters , 7.4 pushrods
the top end of my motor sounds like a sewing machine , very noisey is this normal after a head and cam change ?
car runs mint , makes good power , oil psi is good ( 45-50psi on the highway/ 30-35 idle ) ran 10.91 @ 125 friday night
pushrods too short maybe ?
Old 08-01-2010, 08:27 PM
krissoto's Avatar
Oh yea my friend, most, if not all ls cars have the sewing machine sound after a cam swap. Its what they do.
Old 08-01-2010, 09:04 PM
RedRallyeZ's Avatar
ive got a torquer 3 and i do have a good bit of valvetrain noise too, these cars just seem to be noisy after a cam install. You can play around with different oil weights to see if anything thicker helps, but unless you have a wrong sized pushrod, everything is normal
Old 08-01-2010, 11:30 PM
X-ray's Avatar
Did you measure for your pushrod length?
Old 08-02-2010, 12:54 AM
180ls1's Avatar
what lobes are on the t3 cam i have never heard of it?
Old 08-02-2010, 10:01 AM
synisterC5's Avatar
LSK on the intake, and XER on the exhaust. The fast ramp rate of the LSK will make some noise! Just to be safe though you should always measeure your preload. One of our sponsors has the comp cams adjustable pushrod tool for $15, cheap asurance.
Quick Reply: my motor sounds like a sewing machine ...normal for an LS ?
