need help, looked for everything, plz help
Old 08-01-2010, 09:00 PM
383camaroz28's Avatar
Default need help, looked for everything, plz help
ok so i did a cam swap, pulled the motor out painted the bay, sanded all the grounds, cranked it over an started but no tach, tach runs off the cps. changed that nothing, checked the grounds on back of head nothing.
could this cut wire shorted out an be my problem?
i washed my bay before relizeing it was exposed.
how do i run a new wire, it goes from pcm to ....
any help will work plz!
Old 08-02-2010, 06:38 AM
Old Geezer's Avatar
Looks like there may be more than just that white wire that's in trouble.. The green looks to have been "toasted", too.
I'd separate the bundle and start looking.
Old 08-02-2010, 08:17 AM
Whats that green wire control?
Old 08-02-2010, 08:21 AM
also it worked before cam swap
Old 08-03-2010, 07:20 AM
Okay so im geting a tach out singal. I hooked up a 2in tach to that white. Ground. N pos an the mini tach works, i have a bwd cam sensor gonna swap it for a acdelco.
Could the tach just have died?
