Fueling & Injection - where do I buy the T fitting to run twin pumps
ThunderstuckN20
08-02-2010, 02:58 AM
my 2 walbro gss 340s came and i am going start the install and have read the stickys(thanks ls1 tech) but i need to know where to buy all of the supplies needed, i know i need the T fitting and have heard fuel hose and fuel injection hose, but who sells T fittings??? i want to use what works best and don't want to cut any corner i want to know what works the best because i only wanna do this once .........i wish there was more specific in depth instructions thanks for you help ls1tech
GrannySShifting
08-02-2010, 09:09 AM
You definitely DONT want a T fitting, you want a decent Y fitting that will flow halfway decent. The only one we use that anywhere near compact is a stainless steel Y about 1.5" long and 3/4" wide, much more compact than the yblocks you can get at Summit etc
And onthe hose reg fuel injection hose is not good enough for in tank use, you need SAE 30R10 rated submersible line, Ive done many dozens of fuel pumps in these cars and reg hi pressure FI hose (SAE30R9) is not holding up over time. That hose is expensive as hell, but you only need it to get it out of the tank
unclebens
08-02-2010, 10:16 AM
I need a short Y fitting, do you have the brand or link to where I can buy one?
FasTimeSS
08-03-2010, 01:27 AM
home depot sells a 3port but i we only use a 2 port. mity mouse used the 3 port in his write up.
No Juice
08-03-2010, 09:59 PM
I'm interested in this Y as well, where can we get it
ls6427blown
08-03-2010, 10:08 PM
this place in texas had them i cant think of there name it will come to me
RedVertTA
08-07-2010, 03:12 AM
http://www.charliedigital.com/content/binary/comment-friday-damn.jpg
Dual 340s? What are those puppies feeding?
unclebens
08-07-2010, 09:44 AM
Duals is not really that big of deal. over 550whp you need to start thinking about using dual walbros. Over 400whp on e85 needs duals. Now the hat trick triple walbros, that is when you are getting serious :)
MIGHTYMOUSE
08-07-2010, 10:10 AM
http://richmondperformancemusclecars.com/photos/mm/images/26310/original.aspx
cheap and ready for the third pump when the time comes
Frost
08-07-2010, 12:39 PM
Yeah... if they have a 98. Try fitting that giant shower head (:jest:) into a 99-02 bucket.
RedVertTA
08-07-2010, 06:41 PM
I'm perfectly aware of this. It is not the fact that he is running duals that impresses me but rather that he is running dual 340s. Good bit of difference in capacity between this setup and the mainstream dual 255 setup.
Regardless I'm still curious about the motor.
505OUTLAWZWS6
08-08-2010, 10:08 AM
You are not aware of much.... A gss340 is the part number of a walbro 255 pump.
RedVertTA
08-08-2010, 05:50 PM
I was under the impression that 340 was the flow rating, I've never heard of anyone call it a 340. Thank you for correcting me, it was my mistake and I take it back.
unclebens
08-08-2010, 07:11 PM
Your not the first to make that mistake. I wish people wouldn't call it a 340 it confuses people. Besides the gss340 is still around but most GM applications have been moved to an updated f20000169 part number. Still 255lph rated which is the largest universal pump walbro makes.
No Juice
08-12-2010, 09:19 PM
ttt.... for more information on the Y fitting
unclebens
08-12-2010, 10:44 PM
so where do you buy it?
MIGHTYMOUSE
08-13-2010, 08:33 AM
check my sticky thread.
unclebens
08-13-2010, 10:19 AM
Ok, so you got it at home depot. was that in the plumbing section sir?
GrannySShifting
08-13-2010, 12:09 PM
I have some barbed stainless steel y blocks that I use, not sure where I got them from i got a bunch for projects in the shop, MUCH more compact than the showerhead type stuff
Jeff Smith
08-13-2010, 03:32 PM
Possibly yeah ..I ll look around in plumbing area..If I find one, I ll post..
Sticky here...:cheers:
No Juice
08-13-2010, 03:54 PM
Can you post some pics of this said "Y" block?
505OUTLAWZWS6
08-15-2010, 11:24 PM
Its in the tools section, where the air fittings are.
Cheatin' Chad
08-16-2010, 03:59 AM
I have one of those fittings on my air compressor. I got mine from home depot by where they sell the air compressors.
MM:What you've accomplished with what you've used is pretty fucking impressive.
No Juice
08-27-2010, 08:29 AM
ttt...for some pics of this part or more information on it.
robbyredneck
08-27-2010, 09:30 PM
i bought a stainless y on ebay advertised for lightning duals. cost me thirty bucks shipped but man it is perfect.
unclebens
09-26-2010, 02:33 PM
mightmouse, so looks like you have the dual pumps pushing through the stock 5/16" or is it 3/8" tube on the lid. How much horsepower do you have? I am wondering if that setup will support 700whp on e85?
nolo200
09-26-2010, 02:53 PM
I agree...be sure to increase the size of those long fuel lines. It'll save your pumps from having to work harder than they should have to.
MIGHTYMOUSE
09-27-2010, 04:09 PM
that particular set up was not done for my own car, but was done for around 700rw capable.
mine is this
http://px6.streetfire.net/0001/59/57/1909575_600.jpg
unclebens
04-26-2011, 01:11 PM
mightymouse, are you using the factory tube through the lid or are you using an AN fitting through the lid? I would like to use the factory tube coming out of the lid, just not sure how much whp it will support on e85
MIGHTYMOUSE
04-26-2011, 04:28 PM
answered pm
