If i deck my heads .010 my pushrods should be that much shorter for same preload?
Old 08-02-2010, 09:00 PM
BigRich954RR's Avatar
Default If i deck my heads .010 my pushrods should be that much shorter for same preload?
If i deck the heads a little or get thinner head gaskets my pushrods should get smaller by the same amount to keep the same preload right ?
Old 08-02-2010, 09:35 PM
Rhino's Avatar
It may not be the exact change in length, but it will be pretty close.
This is all assuming your pushrod length is optimal prior to milling or the thinner gasket. I don't really like to leave something like this up to chance. I would break out the adjustable pushrod and insure that it's correct.
Old 08-03-2010, 04:37 AM
vettenuts's Avatar
Unless you are doing custom pushrods, 0.010" change in length can't be purchased so you may not even need to change them (increments in length is typically 0.025"). Always good to verify though. What is the current preload and what lifters are you running (do they have a very narrow preload range)?
Old 08-03-2010, 06:46 AM
im running the morrels lifter. but im looking to deck the block a little to clean it up and the heads. So not sure what my final amount will be but was just wondering
Old 08-03-2010, 06:48 AM
SweetS10V8's Avatar
I think your splitting hairs......010" on a street engine isnt worth thinking about really.
Old 08-03-2010, 07:19 PM
I think my preload is at . 025-30 how much is noramlly taken off the heads to clean them up if there not leaking just to be sure they prefect straight
Old 08-04-2010, 05:07 AM
vettenuts's Avatar
Morel lifter preload should be between 0.030"-0.050". Depending on your current preload, when you mill/deck you should re-measure and confirm you are still within the range of preload for the Morels. I got those preload values straight from Morel a few years back. I run mine at the upper end and found it to be very quiet.
Quick Reply: If i deck my heads .010 my pushrods should be that much shorter for same preload?
