Compression of 2004 6.0L
Old 08-03-2010, 04:56 AM
TurboChris's Avatar
Default Compression of 2004 6.0L
I've put a 6.0L from a 2004 Silverado in my 87 Buick Turbo T. I've heard everything from 8.8 to 9.6 for compression. Does anybody know for sure. Thanks, Chris.
Old 08-03-2010, 01:39 PM
supershift67's Avatar
I have read 9.6.
This is off of a GM spec sheet.
Old 08-03-2010, 03:44 PM
kevin87turbot's Avatar
It depends on what vehicle it was removed from. In 2004, it could be an LQ4 or an LQ9. If it's an LQ4, it's 9.4:1, if it's an LQ9, it's 10:1.
Old 08-03-2010, 06:16 PM
Jimbo1367's Avatar
LY6 (LQ4 replacement) is 9.6:1
Kevin87turbo has it
Old 08-03-2010, 07:20 PM
TurboChris's Avatar
Thanks guys. Would any of you happen to know where I can get the exact cam specs. Its an LQ4, by the way. Thanks again everybody, Chris.
Old 08-03-2010, 11:10 PM
For the 2004 model...PN 12561721,
'01-'06 LQ4, Int. 196 0.467 116
Exh. 207 0.479
Here's some good reading on LQ4's...http://www.carcraft.com/projectbuild...ock/index.html
I did the same swap that you're doing, so here's a link to my build up...
http://www.turbobuick.com/forums/tur...onversion.html
Quick Reply: Compression of 2004 6.0L
