flywheel balanced
Old 08-04-2010, 08:51 PM
1toofastlt1's Avatar
Default flywheel balanced
Im building a balanced 383 but i want to run the stock heavy flywheel for drivability. do I need to get it nuetral balanced or are they already like that stock? thanks
Old 08-05-2010, 12:17 PM
BALLSS's Avatar
assume your 383 will be a "internal" balance motor...than yes you can have a stock FW "neutral" balanced. On the stock FW the weight is cast into it so it will need to be ground off and possibly some material removed from other parts of the FW. A good machine shop should be able to do it for about $40...also get it resurfaced. I paid $50 for both on mine.
don't have a pic of back (engine) side but note where the shop put pins in the outer holes to balance it after they ground off the cast weight.
also have your PP neutral balanced to the FW..in the pic you can see where the shop took material out of the PP edge.
Attached Thumbnails flywheel balanced-clutch-inst-4-flywheel.jpg   flywheel balanced-cn-pp-bal-26-grm.jpg
Old 08-05-2010, 01:07 PM
ok awesome. thats was a lot of help with the pic. Thanks
Old 08-05-2010, 04:33 PM
Village Troll
SS RRR's Avatar
To have your flywheel properly balanced you want to give the machine shop the pressure plate you are going to be using as well.
Quick Reply: flywheel balanced
