Dynamometer Results & Comparisons - EPS Cams
View Full Version : EPS Cams
BlackScreaminMachine
08-05-2010, 11:56 AM
I did do a search, came up with a lot of either larger cube combos such as LS2 H/C, or even LS6 dynos. ** I did read the "Baby ESP Cam"
I am mainly looking for results and driveability opinions on ESP based cams and in the confines of being a cam only (heads/cam ok if you have them), 346 LS1 based appllications, Fbody specific. Pls list drive train too.
I currently have a VRx4 From Vengence (228/230 @ .58x lift on a 112 LSA) and I like it, it does alright. May be looking at upgrading in the future and at this point, aside from going with a tried and true TRex I may consider custom ground.
My car has a 3" STEEL DS, Moser 12 bolt with a Tru Crap Diff, 33 Splined Axles. Stock 2002 Heads and LS6 intake and self hand ported TB. Dynatech 1-3/4" LT's with Cats to a Corsa. T-56 with a Textralia Clutch, their flywheel.
Made 384 RWHP and 363 RWTQ which is ok, but not what I have seen from the same cam in other cars.
So if you have anything, please post.
Thanks
Vindicated346
08-05-2010, 12:14 PM
about 7 or 8 threads below yours is a thread with a "baby" eps cam laying down 430/415 through and A4
08-05-2010, 01:13 PM
Yea thats the only one I have seen, anything else?
Patrick G
08-05-2010, 01:19 PM
Try these:
http://www.ls1tech.com/forums/dynamometer-results-comparisons/1175468-pat-g-spec-cam-results-226-230-mike-norris-tuning.html
http://www.ls1tech.com/forums/dynamometer-results-comparisons/1307451-cam-only-ls2-c6-vette-makes-503rwhp.html
http://www.ls1tech.com/forums/dynamometer-results-comparisons/1213394-baby-eps-cam-lays-down-430rwhp-415rwtq-track-results.html
http://www.ls1tech.com/forums/dynamometer-results-comparisons/1132839-403-rwhp-ls1-stock-exhaust-manifolds-mild-cam.html
http://www.ls1tech.com/forums/dynamometer-results-comparisons/1255345-tsp-5-3-stage-2-5-heads-patrick-g-spec-cam-dyno-numbers.html
http://www.ls1tech.com/forums/dynamometer-results-comparisons/1222185-tfs-215-heads-fast-92-add-67-rwhp-cammed-vette.html
http://www.ls1tech.com/forums/ls1tech-sponsor-feedback/1213375-geoff-engine-power-systems-rocks.html
http://www.ls1tech.com/forums/generation-iii-internal-engine/1175555-engine-power-systems.html
08-05-2010, 02:10 PM
Much Appreciated I got some searching to do.
69LT1Bird
08-05-2010, 04:19 PM
......or just have Patrick spec you one or go right to the owner of the actual lobes, Geoff at EPS, and he will take care of you.
1c62nv
08-05-2010, 10:07 PM
;)Thanks Patrick, try this one. Its my favorite:devil:http://www.ls1tech.com/forums/dynamometer-results-comparisons/1307451-cam-only-ls2-c6-vette-makes-503rwhp.html Just jokin yall have fun
08-06-2010, 06:26 AM
Doing research.
I tend not to waste people time before buying and the MAJORITY of cam guys do not give away specs for free.
08-06-2010, 08:37 AM
I have finally gotten a chance to search through all the links and definitly seems the custom lobes that they use gives a "less is more" feel to the results. One or 2 of them based on smaller specs were a touch above where I was at but since there is potential for making well over 400, there is definite hope.
Much appreciated on the links everyone, hopefully this will narrow the decision down a bit.
