Need a clutch....Recommendations?
Old 08-05-2010, 05:36 PM
my01ws6's Avatar
Default Need a clutch....Recommendations?
Hey guys Im just looking for a stock like clutch. As cheap as possible. I just need a clutch to drive around on for a bit and to trade it in. My clutch now is BAD. I think my flywheel is warped. I have a REALLY REALLY bad shutter every time I take off and basically have to slip the hell out the clutch to make it not shutter really bad.
I looked on ebay and found an F1 Racing clutch disk for $100 any one on here use one of these and can I reuse my stock pressure plate?
I also found a spec stage 1 for $260.
what do you guys think? Would you guys recommend something different?
Old 08-05-2010, 07:22 PM
RsSean's Avatar
Monster clutches!
Old 08-05-2010, 11:00 PM
hivoltagedriver's Avatar
I'd also reccommend Monster, but they may not be in your budget.
Old 08-06-2010, 08:22 AM
crainholio's Avatar
The LS7 kit SDPC sells is about the best deal cost-wise, and it works well. All new parts from the flywheel back.
Don't plan on re-using your pressure plate.
You might get off cheaper by having your flywheel machined and just buying a new disc and pressure plate, depends on what condition it's in.
Old 08-06-2010, 09:49 AM
raven154's Avatar
Just buy the cheapest stock replacement you can find if you're just going to trade it in.
Old 08-06-2010, 12:05 PM
SPEC-01's Avatar
Though I am all about selling you a clutch kit you really may be able to find a stock assembly for less. Check our Google/Ebay/Etc...and let me know if you need anything else.
Old 08-08-2010, 02:12 PM
TDP
TDP's Avatar
I've got a low-mile stock clutch and flywheel for $175 shipped. Call if interested.
