LY6 No start no injector pulse
Heres the scoop. 07 LY6 E38 ecm. Have Crank, Cam signal. Has spark. No injector pulse. VATS is disabled and car will run if you spray brake clean in the intake. My Modis scanner shows that it has injectors pulse. HP tuners shows injector pulse but i never get a noid signal. All injectors have power during cranking and key on.
Things im not sure of. Accessory wakeup serial data wire?
What does this do and what should it be hooked too?
With a volt meter hooked to power and to the ground side of the injector wire it will show ground with key on. Normal? But the ground will not light a test light.
Any help would be greatly appreciated.
THanks David
THanks David
Here is what I found on the accy serial data wire. Looks like it shouldn't have to be connected.
The accessory wake up line is an accessory fed power feed to the ECM and TCM (etc).
It is there in most cases to support "wake up" of low speed serial data when the key is on accessory, vs ignition on/engine running.
Have you checked the fuel pressure at the rail? You are showing injector pulse while cranking? My LY6 cranked and ran from the first time I put power to it. I do not have the accessory wakeup wire connected.
I just cranked my L76 on my test stand over the weekend and it was pissy about cranking. It finally did, but it was difficult about it.
Do you know if you have your fuel pump set to "Fixed"? Seems like my LY6 was not and I had to change that setting.
Bounce some more ideas off me and I can check them against my LY6 setup.
Don't know if you will be back online, but I just went through my LY6 startup today. Without your help it would have taken me days to wring it out. The grounding of the fuel pump relay and starter relay ECU pins were the last key issues.
Thanks much.
v10rodder
Thanks much.
v10rodder
you guy are the best
Found your thread, and it pointed me into the correct place after a week.ran the wire, no go, shot the Camshaft position no go, changed the disable engine crank, and off the beast went. cheers to all
71 GMC stepside LY6/6L90
