rear end gears broken affecting my mph
hey guys was just curious the guy i bought the car from its a 95 ta auto did something with the gears said there stock and just replaced the bearings well he forgot to put oil back in but the time i got to drive it the mph is way off showing faster than i am going for instance maybe actuall 15 mph but showing 45 + i just got a new trany for it 3600 stall trans go shift kit ect know putting a 97 ws6 rear end hopefuly this rear end will work for my car and will fix the problem with the mph also gas gauge not showing when its empty shows quarter left could it be the pcm/ecu....
Jk man, the autos had different gearing than the manuals. Auto's had a 2.73 or 3.23 gear, manuals 94 and newer came with 3.42's...if the speedo is off its probably just because of the gearing like the others said. If you get a tune you can switch whatever gears you have into your tune to correctly calibrate the speedo...
Read your owners manual, i beleive it says "IMPORTANT: NEVER RELY ON A FBODY'S GAS GAUGE IN MODELS RANGING FROM 1982 TO 2002 AS IF YOU HAVE ANYTHING BUT A FULL TANK OF FUEL IT WILL MOST LIKLY READ WRONG"
its in there somewhere, trust me.
i think the gas gauge problem is different for different cars. mine reads just fine. when i get real low close to empty the the gas gauge freaks out. but im going to guess its different for ever car.
we purposely tried to run it out of gas so when we dropped the tank it would be easy. i think there was about a 1/8 inch of gas left in it.
i dont trust mine at all. get around half a tank, take a turn, hit the brakes, it can go anywhere from 3/4 tank to 1/4 tank lol. perhaps something just wears out in them.
