Drag Racing Tech - HVAC delete and water pump fittings???
DTB_LS1
08-07-2010, 05:20 PM
Hey guys, what is everyone doing with the water pump fittings when deleting the HVAC system? Can I just loop the the fittings with some heater hose til I get a EWP?
trans2000am
08-07-2010, 05:57 PM
you can just plug them with a rubber fitting an put a clamp around it.
airfix
08-07-2010, 06:15 PM
You can loop them or cap them. I origionally looped them but it looked like shit. So I took the pump off removed the conection pipes and tapped the holes and used some npt plugs. Looks much cleaner and it is easy to do.
Now My car is a LT1 but its the same idea.
DTB_LS1
08-07-2010, 06:23 PM
Cool, thanks guys.
studderin
08-08-2010, 08:28 AM
anyone use freeze plugs?
ATwelveSec02Z28
08-08-2010, 08:33 AM
Vacuum Caps?
trans2000am
08-08-2010, 12:53 PM
Vacuum Caps?
yup just make sure they are a lil thick and use a clamp on them also
airfix
08-08-2010, 02:43 PM
I was origionally gonna get my pump welded up but my welder bitched out and didn't want to do the job. Then I was going to use freeze plugs but my auto parts store didn't have the sizes I need so I tapped them and used plugs. Im pretty sure a few people have used freeze plugs though.
airfix
08-08-2010, 02:45 PM
Vacuum Caps?
Vacuum caps always seem to dry out and crack after a few months. Not a good thing if the decide to let go when your haulin ass down the track.
b_offill
08-08-2010, 09:04 PM
Local parts store should have the caps you need, they are not vacum caps. They are darn near as thick as your radiator hoses.Used them in the past on a couple cars.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
