Have an LS1 car and a LT1 car, how hard is it to swap brakes from each other?
Old 08-08-2010, 12:04 PM
Black94Z28's Avatar
Default Have an LS1 car and a LT1 car, how hard is it to swap brakes from each other?
Ive done a search but didnt find anything involving both. I have a guy with a LS1 car looking for lt1 brakes for drag wheels and wants to swap with my stuff. Is this going to be a major project or is it just pulling the calipers and rotors and swapping?
I dont want to mess with changing stuff out like master cylinders, prop valves, lines, etc.
Old 08-08-2010, 01:06 PM
robsquikz28's Avatar
Just swap it over MIke, no issues
Old 08-08-2010, 01:29 PM
96lt1m6's Avatar
All you need is an afternoon, basic tools etc.....
Unless your car has aftermarket gears in there i would swap the entire rear end just cause its easier. The front is simple,remove tie-rod end,lower ball joint upper ball joint,brake line from frame.....
I am sure you know this but PLEASE USE JACK STANDS!!!!!!!!
Old 08-08-2010, 01:30 PM
the_merv's Avatar
Front Spindles, Calipers & Rotors, rear Backing Plates, Calipers, Rotors, and Ebrake Cables.
Old 08-08-2010, 02:17 PM
Badazz 97 TA's Avatar
fronts are easy. Just a few hours. Its really not any more involved then just swapping calipers. spindles are easy to remove. Merv mentioned what you need. thats all there is too it.
Old 08-09-2010, 11:58 AM
95ZR28's Avatar
Everything ive heard and read its easy! Im about to do it with my 95zr28
Old 08-09-2010, 12:21 PM
Black94Z28's Avatar
and no issues for him going to lt1 brakes?
Old 08-09-2010, 04:51 PM
nope. its a direct swap either way.
Old 08-09-2010, 11:27 PM
Black94Z28's Avatar
thats what i want to hear!
Old 08-10-2010, 10:05 AM
the_merv's Avatar
Originally Posted by 95zr28
everything ive heard and read its easy! Im about to do it with my 95zr28
zr28?
