Bare heads - Trickflow
Old 08-08-2010, 11:31 PM
gregrob's Avatar
Default Bare heads - Trickflow
Thinking about getting these bare since I plan on using the springs I already have on my stock heads.
Who has done this? Would a valve job be required? If so I'll probably get the assembled version then keep the springs for spares or let someone have them cheap.
Might save money that way rather than getting them bare then having to buy valves and get the machine work done.
Opinions?
Old 08-08-2010, 11:35 PM
1badzee's Avatar
It's sometimes cheaper to buy them assembled, but you need to make sure they will be sufficient enough for your setup. Some setups require different springs with different install heights, etc. But since you are using your springs, then go for it. Are they for a future build or will they be complimenting your current engine?
Old 08-08-2010, 11:44 PM
gregrob's Avatar
The springs would be fine for my cam but I already have better double springs so no reason to use the trickflow ones. They will be going on my current stock shortblock.
Old 08-09-2010, 11:44 AM
Wyocattech's Avatar
Hey greg what ones are you looking at? cc, runner size, ETC.
Old 08-09-2010, 11:46 AM
gregrob's Avatar
The new ones, 54cc 185 intake I believe. 21 degree
Old 08-09-2010, 04:53 PM
Badazz 97 TA's Avatar
i would go with cast iron. iTs sound better and the valves are bigger and made of aluminum.
Old 08-09-2010, 05:43 PM
Wyocattech's Avatar
Your heads stock with springs? Id get new valves and yeah id say u would probably need a valve job to insure valve seat angles are right. Or give AI a call and get the same package i got.
Old 08-09-2010, 06:08 PM
joelster's Avatar
Get them assembled, you'll save $100's
Old 08-09-2010, 08:37 PM
gregrob's Avatar
Yes my heads are stock with springs. I dont want the AI stuff. I'd rather do something a little different.
Kinda what I'm thinking..
Old 08-09-2010, 09:33 PM
vanilla89's Avatar
the bare ones ive seen come with cnc chambers and a valvejob allready done..
they are back ordered so youll probley be waiting about 3 weeks for them...
Old 08-10-2010, 06:07 AM
joelster's Avatar
My bare TFS heads did not come with a valve job, but I got the 195cc ones, and this was when they first came out.
Quick Reply: Bare heads - Trickflow
