New Heat Shield for my K&N
I made this heat shield with hopes it would reduce the hot air used from the motor. I don't know if this is going to made a huge difference but i can't hurt!
I mocked this up out of card board to get the fit with-in a 1/8 " of the hood so I could make the seal tight with some insulating foam up under the hood. I don't like the look of the seal being on top of the heat shield. The 3/16 alum. was easy to work with. I painted it flat black to match my intake. I made the tabs to hold it on work in the holes that were in my intake plate so no more were needed. I think it turned out pretty good. What do you guys think?
The air has to get there the same way sooner or later. It may come from a different direction on yours (maybe) but it still flying passed your filter!
And 01 drop.
I saw a cold air intake that had two filters(can't remember the brand) that had a shield kinda like this. So I knew it couild work. Just a little different fit and shape.
And 01 drop.
And 01 drop.
And 01 drop.
Put that seal on it and take the baffles out and it makes a difference but your filter will get dirty in 0-60... lol
