Cheap Shorty Headers
I am searching for cheap and I mean cheap set of shorty LSx headers. I'm building a low budget 944/5.3 for the Grassroots Motorsports Challenge so my budget is set at $2010 now it looks like it'll be next year due to work and time constraints.
So, I've got a little breathing room to finish the car. I know that there has to be someone out there who has an extra set of headers they don't need.
Regards
Mark
Regards
Mark
Andy1
I have seen cheap sets of block huggers out there sub $200. Can't place where however.
There are individuals on here that use 5.0 stang headers with LS flanges. This combo, if you strike the right sales can be sub $100. Don't know how much cheaper you can get!
Good Luck.
Good Luck.
I had steering shaft interference with shorty headers, GTO, manifolds, and CTSV manifolds.
Ultimately what fit for me were 2006 5.3 Truck manifolds. You can probably find some cheap enough to try, and easily resell because people use them for turbo kits fairly often.
Thanks for all your suggestions. So far the "best" header is a proven and documented modification of an off the shelf hooker header. That throws a wrench in my budget.
I found a used set of ford shorty headers on craigslist that might be a possibility.
If you have other suggestions I'm open.
I was just thinking that as I looked at the Porche link. REAL small primaries.
Ill be running the Sanderson short block huggers for my Jeep conversion. They aren't "cheap" but they are certainly quality parts. I would have run the Hooker headers, but they won't clear my motor mounts.
Summit also makes a set there were close, but the dump is to far forward.
I have a friend running LS2 headers that are fairly short and cheap. I would run these, but Im having issues finding a set...
