Katech_Jason
08-09-2010, 02:57 PM
We are having a sale from now until the end of the month. Select items are up to 30% off. See the list below for a list of items and links to our online store.
Please note that the online store can only handle one coupon at a time so if you want multiple items that have a different discount percentage, please place a second order using the correct coupon code. We will combine shipping wherever possible. The coupons will autocoupon (apply automatically), but they are stored as cookies in your browser. If you initially select an item that is 15% off, that is the coupon that will apply for the rest of your website visit. If you wish to change coupons, click remove next to the coupon in the shopping cart, then click the enter coupon button to re-enter the correct coupon code. Coupon codes are listed below.
30% off items - coupon code "Aug201030"
Billet thermostat housing http://store.katechengines.com/billet-thermostat-housing-p49.aspx
Billet water neck, no thermostat http://store.katechengines.com/water-neck-no-thermostat-p115.aspx
25% off items - coupon code "Aug201025"
TRAC camshaft http://store.katechengines.com/trac-camshaft-p10.aspx
15% off items - coupon code "Aug201015"
Billet belt tensioners for Corvette/CTS-V http://store.katechengines.com/billet-belt-tensioner-p3.aspx
Billet belt tensioners for Camaro/Firebird/GTO http://store.katechengines.com/billet-belt-tensioner-p2.aspx
Billet belt tensioners for Trucks http://store.katechengines.com/billet-belt-tensioner-p4.aspx
Billet belt tensioners for Corvette w/ARE S3 dry sump http://store.katechengines.com/billet-belt-tensioner---no-pulley-p146.aspx
Billet main caps http://store.katechengines.com/billet-steel-main-caps-p26.aspx
C5-R timing chain http://store.katechengines.com/c5-r-timing-chain-p30.aspx
Exedy twin disk clutch http://store.katechengines.com/exedy-twin-disk-clutch-kit-p88.aspx
LS9 head stud kit http://store.katechengines.com/head-stud-kit-ls9-p203.aspx
Spark plug holder http://store.katechengines.com/holder-spark-plug-p227.aspx
Hot Rod LSX 427 crate engine (only 1 available at this price) http://store.katechengines.com/hot-rod-lsx-427-crate-engine-p216.aspx
High Capacity LS7 oil pump http://store.katechengines.com/high-capacity-ported-ls7-oil-pump-p175.aspx
Ported LS1/LS2/LS6/LS3 oil pump http://store.katechengines.com/oil-pump-p5.aspx
Torquer LS7 110 camshaft http://store.katechengines.com/torquer-ls7-110-camshaft-p11.aspx
Torquer LS7 116 camshaft http://store.katechengines.com/torquer-ls7-116-camshaft-p223.aspx
PSI LS1511 valve springs http://store.katechengines.com/high-lift-valve-springs-p8.aspx
Titanium valve spring retainers http://store.katechengines.com/titanium-valve-spring-retainers-p9.aspx
Jacking pucks http://store.katechengines.com/jacking-puck-p68.aspx
CTS-V short throw shifter http://store.katechengines.com/short-throw-shifter-cts-v-p24.aspx
7% off items - coupon code "Aug201007"
Billet 500ci LS block http://store.katechengines.com/billet-500ci-ls-block-p201.aspx
Also don't forget to add on some Katech Performance gear before you check out. The following gear is on sale with no coupon code required.
Katech Performance logo T-shirt - ONLY $7!
*2XL $9
http://www.nexternal.com/katech/images/KAT-6045_lowres1.jpg
http://store.katechengines.com/katech-performance-logo-t-shirt-p194.aspx
Katech Performance logo flex fit hat - ONLY $7.50!
http://www.nexternal.com/katech/images/KAT-4477%20low%20res11.jpg
http://store.katechengines.com/fitted-hat-katech-performance-logo-p58.aspx
Katech Performance mechanic's gloves - ONLY $19.00!
http://www.nexternal.com/katech/images/KAT-50431.jpg
http://store.katechengines.com/katech-performance-mechanics-gloves-p197.aspx
Katech Performance black polo shirt - ONLY $13.50!
*in select sizes while supplies last
http://store.katechengines.com/polo-shirt-katech-performance-logo-p59.aspx
Both sales end August 31st
*2XL $9
