opti question about ordering
Old 08-10-2010, 11:32 AM
ryanosborne's Avatar
Default opti question about ordering
im ordering a acdelco opti from my local dealer and i was wondering what else i need to order with it to change it out?
Old 08-10-2010, 12:48 PM
RamAir95TA's Avatar
Besides little stuff like water pump gaskets, thread sealant, etc., nothing else from the dealer.
Old 08-10-2010, 01:21 PM
and where should i get my timing set?
Old 08-10-2010, 01:24 PM
RamAir95TA's Avatar
You really should consolidate all of your questions into one thread. I can't keep track of what exactly you're doing, what optispark you have, what year car you have, what motor, what water pump, etc.
Old 08-10-2010, 01:33 PM
1994 firebird formula, buying stock opti and stock water pump. i cant get a stock timing set because its discontinued
Old 08-10-2010, 01:42 PM
1993 z28 f1's Avatar
Hey:
Why not get a Chandler Motorsports Opti, an CSR EWP, and a double roller timing set. It would be cheaper and as good an OPTI and better money spent than the other stock stuff from the dealer.
Dub
Old 08-10-2010, 02:34 PM
JAKEJR's Avatar
The Opti issue has been coming up a LOT on other Forums too. The general consensus is to only use an ACDELCO OPTI. Guys are posting about all sorts of problems when using other brands, even the MSD's model.
Best I can do is pass along what they're reporting: you can check Corvette Forum on the C4 Engine Tech board and LS1LT1.com LT1/LT4 board. A search will pull them up.
Hope this helps.
Jake
Old 08-10-2010, 03:12 PM
shbox's Avatar
Who said? I just looked up all the numbers. They're still good.
Old 08-10-2010, 03:30 PM
well at the only gm dealership in this town they said they are and they cant get it for me
Old 08-10-2010, 03:38 PM
shbox's Avatar
Then, don't use them. Lots of places online to order from. Even places like Summit, etc, carry stock sets.
Old 08-10-2010, 07:00 PM
summit carrys stock ones? because im ordering alot of stuff from them this week
Old 08-10-2010, 07:08 PM
this timing set work? http://www.summitracing.com/parts/CLO-9-3151/
Old 08-10-2010, 07:18 PM
TABBED 5.3's Avatar
that seems pretty expensive for a timing set. if the motor is stockish you can get a set (chain/gears) from one of the local parts stores for around 90 bucks if i remember right. I asked them for a replacement set and it was a cloyes. hope this helps save you some money.
Old 08-10-2010, 07:32 PM
would napa carry a good timing set for a stockish lt1?
Old 08-10-2010, 07:59 PM
shbox's Avatar
Nope, won't work. That's for a vented opti. A 94 has a non-vented opti.
This would work and is basically a stock GM set.
http://www.summitracing.com/parts/LU...n/?prefilter=1
I thought they carried the GMPP stuff, but maybe not.
Old 08-10-2010, 09:51 PM
but it says its for a 94? and that one says its for a 92, 93? mine is a 94. im confused
Old 08-10-2010, 10:01 PM
shbox's Avatar
I know it is confusing. It all depends on which body style (Y, F or B) they are referring to. Anyway, look closely at the cam gear. The one I said would work has the splines in the center required to drive your non-vented opti. The 3151 does not and has a larger hole in the center meant for the vented opti.
Old 08-10-2010, 10:25 PM
Hey:
OP
This is most of what you need minus, OPTI vent kit, 95-97 OPTI cable harness, gaskets and seals.
You could also add 1.6 7/16" roller rockers, pushrods, 7/16" studs, and trickflow guideplates, but could be added later, and would have spent a little more than just buying the GM dealer stuff. You would have a newer style more complete upgrade rebuild kit. Just some info for you to ponder.
http://cgi.ebay.com/ebaymotors/new-o...Q5fAccessories
http://www.summitracing.com/parts/NAL-24502586/
http://cgi.ebay.com/ebaymotors/Cloye...mZ330455448374
http://img159.imageshack.us/img159/9710/tc1eh2.jpg
http://cgi.ebay.com/ebaymotors/LT1-t...ts_Accessories
http://cgi.ebay.com/ebaymotors/CSR-P...ts_Accessories
http://cgi.ebay.com/ebaymotors/CHEVY...ts_Accessories
http://cgi.ebay.com/ebaymotors/VALVE...ts_Accessories.
Dub
Old 08-10-2010, 10:44 PM
l 95 Trans Am l's Avatar
I bought a Delphi (AC Delco) optispark off ebay for 260 shipped
Old 08-10-2010, 11:06 PM
hitmanws6's Avatar
For optis if you are on a budget go with the chandler motorsports, but the delco seems to be the best all around. people seem to forget that that opti that went out years after the car was made and thousands of miles was an ac delco. the only upgrade you should make over the delco is the dynaspark, but those are geared for more racing applications
Quick Reply: opti question about ordering
