Clutch pedal assembaly
is the clutch pedal assembally the same in a v6 car and an ls1. I'm thinking of doing an m6 swap. I've done auto to 5-spd swaps in mustangs, one in a nova and chevelle but never a camaro.
So its not just a clutch and brake pedal assembly? The gas pedal is part of the swap too. Its a 98 LS1, I didn't know they had drive by wire that long ago.
you will have to swap out your gas pedal for a cable one unless you are using drive by wire setup with i would say you probaly are not the is a clip to take that pedal off the set up when u do that you should be able to switch them out
