loudmouth exhaust
Old 08-11-2010, 12:04 AM
Z28-4Ever's Avatar
Default loudmouth exhaust
so i just bought a loudmouth II cat back now i was wondering is it a direct fit to the stock y-pipe, and how do i get the stock exhaust off without cutting it?
Old 08-11-2010, 05:58 AM
08 848's Avatar
Just did mine,
get the car in the air, remove right shock and disconnect swaybar. I removed the panhard top and bottom. Let the rear drop down, the right will drop down more because you still have the left shock connected. Then curse a few new words you just discovered as you maneuver the exhaust out.
I then had to replenish with a gallon of water I just sweated out, it's no joke in Mobile AL in the summer.
Old 08-12-2010, 12:14 AM
Z28-4Ever's Avatar
Does it fit directly up to the stock y-pipe or do I have to get a new y-pipe also
Old 08-12-2010, 03:09 AM
08 848's Avatar
I believe it bolts right up, not 100% though. I'm waiting on parts to do my motor mounts so I didn't install my headers and y yet.
Old 08-12-2010, 03:55 AM
brian_rs/ss's Avatar
be fore warned, it will sound like hammered dog **** if you ever go to a cat less set up.
Old 08-12-2010, 03:56 AM
Originally Posted by 08 848
Just did mine,
or you could just cut the ****** off.
Old 08-12-2010, 11:08 AM
vjo90rs8's Avatar
go to autozone and rent their exhaust pipe cutter. You should be able to cut the exhaust near the rear end so you don't have to remove so many suspension components.
Old 08-12-2010, 11:50 AM
JustAGoat's Avatar
I like the way it sounds and every carshow i go to people tell me how good mine sounds so thats matter of opinion... (I don't want to start another one of those threads so lets leave it at that...)
I wish i knew the fitment of the stock Y with the cat back but mine to has aftermarket y and headers sorry OP.
Old 08-12-2010, 12:13 PM
gyrene2003's Avatar
sounds like ur in the pits at nascar, without cats. Im cammed with TSP catted-y and goin too duals, so go figure, i like the Nascar in the pits sound!!!
Old 08-12-2010, 12:14 PM
gyrene2003's Avatar
and yes, LM will work with stock-y. thats how i started
Old 08-12-2010, 12:51 PM
08 848's Avatar
Yes your correct if the OP said how do I remove my exhaust.
Old 08-12-2010, 01:36 PM
WSsick's Avatar
****, just take a sawzall to it and have some clamps ready. cut short of where you want it to fit so you dont hack off anything. just helped put on a borla cat back this week, took us no more than 30 mins to cut and line it up.
