should i rebuild the engine?
ok so i original plan is to get a rebuild kit for my lt1 and a complete cam kit from ai. but i was told these engines are good for up to 300,000 kms . it for 120, 000 kms. what do you guys think? should i go ahead and get a rebuild kit while i get the cam kit and transmission rebuild kit and im also gettin headers
because a few people owned it before i did and i know the engine has been over heated badly a few times because they didnt know there was a manual switch to turn on the rad fan and i figured if i was getting a cam kit and a rebuild kit for the transmission and a new timing set and opti and headers i may as well get the engine done to but what do you guys think? i know the opti is bad because someone got it wet before and the car sputters and works terrible for the first few minutes you drive it and it hesitates sometimes but once you drive it for a few minutes it works great but i want it to work better and have more power
120,000 kilometers. oil pressure is good. how much of a difference will it have if i dont re do the engine but get the cam kit from ai and replace the timing set and opti and get headers
i know that but do i remove all the plugs put the guage in one hole and turn the key while there are no plugs in it and thats it?
