help with an fittings
i bought like a **** load of an fittings and i dont knw what thread pitch or size they are, for example this lil choad
http://www.summitracing.com/parts/SUM-220648/
homedepot ace hardware no places carry a tap for that, and that is all im tryin to do is tap a whole for that thread size
THANKS
THANKS
I was under the impression that an fittings have to screw into other an fittings or they wont seal, in order to screw it into something else you get a fitting thats an on one side and NPT on the other, then tap your hole with the NPT tap and go with it.
FWIW, oreilly usually has the board that you can screw stuff into and find the measurement.
^^^^ i second this, what are you doing? like said before one side is a 3/8 NPT (National Pipe Thread) the other is a -6AN flare. if you are wanting to screw the -6 (9\16-18") side into a flat piece of what ever it is not going to seal you will have to make it an o-ring seal. http://www.summitracing.com/parts/SUM-220166B/. The 3/8 NPT side will seal because it is a tapered thread.
the -6 side thread pitch
9/16-18"
the 3/8 NPT side thread pitch
3/8 NPT
9/16-18"
3/8 NPT
http://www.jegs.com/i/Earl%26%23039%...67106/10002/-1
You have to go to Sears or Northern...And if they dont have it for whatever reason..Find you a Snap On Truck nearby. Sometimes a large plumbing specialty store or a bolt supplier will have a tap for it. Fastenal is an option as well.
