OLFA table stock or 1.00 with WB tuning
I have read this both ways, some say leave stock and others say set to 1.00 to command 14.7, is there much difference?...Is there a consensus on this?, I have left it stock while tuning and my commanded AFR is slightly rich due to the OLFA table I think and my percent of error is almost dead on, so when I revert to CL won't the trims show this?
1 Post
If your percent error is almost dead on, then your trims should be about dead on when you go back to Closed Loop...
Personally, I tune to 14.7 in Open Loop and use my own table (not as rich as stock, but not totally 14.7 for all ECTs)...
