Exhaust Questions.
Old 08-12-2010, 11:26 PM
l 95 Trans Am l's Avatar
Default Exhaust Questions.
Ok I'd like to ditch my exhaust setup except for the longtube pacesetters. Heres my issue, I bought a cheap used y-pipe and it turned out to be a disaster, exhaust leak heaven to be exact. Basically i threw it together just to get the car streetable. The previous owner messed the magnaflow catback up hardd. Where the catback begins is all messed up, doesnt align up with the ypipe which is messed up in itself, also the piping has a huge dent above the axle, they mustve hit a really hard bump, and to top it off one exhaust tip is more out than the other side, and Ive tried everything to straighten it out. Such a waste of a good exhaust. Id just like to know what your guys' setups are like, so I know what to buy. Im currently looking at SLP and hooker. But not sure of a y-pipe. Opinions?
Old 08-12-2010, 11:54 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Doesn't Pacesetter make y-pipes that go with their headers?
Old 08-13-2010, 12:00 AM
Yes they do however im not sure if they bolt right up to a catback without issues
Old 08-13-2010, 12:16 AM
BTC
BTC's Avatar
A lot of people use Pacesetter headers and y-pipes. I would think they'll work with most, if not all, catbacks designed for our cars. I would be worried about another brand of y-pipe not working with Pacesetter headers.
Old 08-13-2010, 12:18 AM
hitmanws6's Avatar
Just get a pacesetter y and add a good merge to it, the merge that is there is horrible
Old 08-13-2010, 12:21 AM
[QUOTE=hitmanws6;13727888]Just get a pacesetter y and add a good merge to it, the merge that is there is horrible[/Q
By merge, what do you mean?
Old 08-13-2010, 12:22 AM
Old 08-13-2010, 12:25 AM
hitmanws6's Avatar
where the two pipes form the Y. Pacesetter just cuts a hole in the passenger side pipe and feeds the drivers side pipe. Do a search on here for a Flowmaster merge, youll see what i mean
Old 08-13-2010, 02:20 AM
speed_demon24's Avatar
I bought 2 stainless steel 180 degree u-bends and a magnaflow merge and had an exhaust shop fab up the y-pipe. The 2 u-bends had enough straight and bends in them to make up the complete y-pipe out of them.
Quick Reply: Exhaust Questions.
