Hooker Exhaust Rattle On Camaro SS
Old 08-12-2010, 11:44 PM
ryany's Avatar
Default Hooker Exhaust Rattle On Camaro SS
Ok i installed a hooker catback on my 2000 Camaro SS and it making a rattle noise under the car?? Any ideas need help Thanks
Old 08-13-2010, 07:43 AM
Steve Gunn's Avatar
Get underneath and beat on it with your fist to find it.
Old 08-13-2010, 04:02 PM
ryany's Avatar
Thanks alot
Old 08-13-2010, 11:19 PM
DeLaRosa25's Avatar
Find it
Old 08-13-2010, 11:57 PM
WagnutSS's Avatar
i just put my Borla on my SS and had some rattles, so i just slid under it and tapped on it and got each rattle taken care of, had to un bolt the first clamp on the I pipe too and turn the system to keep from rattling on a heat sheild,
Old 08-14-2010, 02:11 AM
ryany's Avatar
Guys Thanks for the replies im gonna get underneath tommorrow and locate it.
Old 08-14-2010, 02:53 AM
Red Devil 99''s Avatar
check all the clamps, and the tips (if you got them) otherwise double check all the clearance between pipe and heat shields.
Old 08-14-2010, 02:29 PM
rob69zombie's Avatar
All good ideas, but none that will fix the infamous "Hooker Rattle". I cut my Hooker open to see what it was and I found it; there is a small cylinder in the walls of the chamber inside that only has 2 small tack-welds on it. Some go for years without any problems and some rattle after first start-up. It's the only flaw I've ever heard from the Hooker and it's been an inherit problem since Hooker started selling them. Maybe you're lucky and it is just a loose connection but it sounds like it's coming from the muffler itself then you can't fix it.
Old 08-16-2010, 05:19 PM
ryany's Avatar
Ok i found the rattle its over the rear end piece thats bumping...
Old 08-16-2010, 10:07 PM
That should be a straightforward fix. Good luck man.
Old 08-17-2010, 07:39 PM
brian_rs/ss's Avatar
you just think it's the exhaust....but really it's time for a 12 bolt.
Old 08-18-2010, 09:51 PM
ryany's Avatar
I hope not
Old 08-20-2010, 03:18 PM
ColossalCamaro's Avatar
Yup, its the over axle. Mine does it too. I tried adjusting with no luck. How about you?
Quick Reply: Hooker Exhaust Rattle On Camaro SS
