Perimeter to Centerbolt - need clarification
Ok so I have a 98z. I am swapping in a crate ls6 longblock and would like some clarification on what parts are needed to get my coils to swap to the new centerbolt design. I've searched part numbers on here, I just want to make sure I get everything I need to swap it all over.
If I understand it correctly, I will need:
LS1 coil bracket (01-02) = 12563288 [2 total]
LS1 coil stud (4 on RH, 5 on LH) (HFH, m6x1x40, special hd) = 12557539 [so 9 total]?
Will my harness and coil bolts [the ones holding the coils to the perimeter valve covers] bolt up to the new brackets and valve covers? Or do I need new coil mounting bolts and a new harness?
Let me know what you guys think. Hopefully I'll get some feedback from someone who has done this swap. Thanks all!
yes everything looks correct.. I just used flange head bolts from the hardware store (well i had them already ) but thats the same
the harness is fine
and you only need to buy the brackets
the harness is fine
