5.3/6.0 into a 85 fullsize bronco
Old 08-13-2010, 03:01 PM
mjs_408's Avatar
Default 5.3/6.0 into a 85 fullsize bronco
Bought a project a 85 bronco as a project truck. Has a 351w-c6-208. Not very exciting as far as horsepower goes(121ish from the factory) It will be cheaper to swap in a 5.3 or lq4/9 than rebuild a 351w for similar horsepower numbers. I am planning on a rewire with new fuse block and all. As currently, the stock engine harness is hammered. The harness Im looking at has several options, HEI hookup, One wire alt ext. and custom options are available. What should I have done to the harness to hook up to a "4-wire hook-up" harness. I am buying a one ton chevy rolling chassis for the axles and m465 and np205. So it will be a bronco with chevy running gear, not the first time this has happened. Who's harness should I use? Ive read about wait4me, speartech, and jims performance. I realize they are probably all similar, but I might need something thats a little from the norm.
Quick Reply: 5.3/6.0 into a 85 fullsize bronco
