Conversions & Hybrids - 400 - 425 HP on 87 Octane - 6.0L (or 6.2L V8)
Need4Camaro
08-13-2010, 05:46 PM
Is it possible to run 87 Octane with L92 Heads on a LQ4 6.0L and a Cam to make 400 - 425 HP? Or do I need to run higher octane? Wanted to build a low compression motor. I was told it wasn't a good idea to run a cam and lower octane as well, but will it work and meet my power goals?
bozzhawg
08-13-2010, 07:22 PM
as long as your DCR is low you can.... the L92 + LQ4 with dish pistons should have you around 9.6.1 comp..... Your DCR would depend on the cam timing events as well but I don't see why not.... If you go to a bigger cam combined with a wider LSA, your only going to bleed off even more DCR
So I say you should be fine.... Just calculate your DCR.......
98SuperchargedLs1
08-13-2010, 07:37 PM
why would you run 87 over 93 when its only 20 cents difference for the extra insurance.. what would you spend an extra 5$ or so to fill the car up big deal
Need4Camaro
08-13-2010, 08:36 PM
35 cents here. I just like the idea of a V8 with big power numbers that can run on low octane, and plus I might plan on Procharging it later.
chevyboy91188
08-13-2010, 09:33 PM
i dont know about the question you asked but im with you on the 35 cents its a joke here in tampa, but up in ohio where the rest of my family lives its only 20 cents difference its an f-ing racket
tennerv8
08-14-2010, 10:29 AM
I currently am running a carbed 6.0 with L92 heads and a comp cam. It is 9.4:1 compression. I also run 87 octane which is just fine for that compression ratio. It really hauls the mail.
