Fueling & Injection - Lucas 120lb Low-Imp. & Versafueler
Blown06
08-14-2010, 02:01 AM
I've done some searching and can't find a whole lot of tuning info out about these. Does anyone on here have experience with them? How are they to tune at idle?
I spoke to the guy at Acceleronics, and he told me to just change the IFR table and I should be pretty close. He said he hasn't seen any need to change the off-sets with these. Sound about right?
Just for reference, I was able to get my Siemens 60's dialed in with just an IRF change, worked VE table, and some idle airflow changes. Idled around 14:1 AFR. Just wondering if these will be that easy. Cam will likely be 23x/24x on a 114-116. Motor will either be 370 or a 427 with Procharger.
Thanks in advance.
camarols1
08-20-2010, 10:34 AM
I'm running the exact same setup on my car, but I am on E85.
The idle might be tough to lean out on gas with a 370, but a 427 should be easy.
I am running mine at 70psi base and the idle PW is right at 2.0ms @ 1.0 Lambda.
My tune is on low boost right now as I learn, but I am very with these bad boys being at 60% duty cycle at 700rwhp~ (6,200rpm .77 Lambda on E85)!
Jim
nahasapeemapetalon
08-24-2010, 08:37 AM
I am running that setup, it idles pretty nice on my 408 with E85. On gas it doesnt idle the best, so its a fine line for me. Cant turn them down enough with gas.
Run E85 and you are good.
Good luck.
Blown06
08-30-2010, 02:54 AM
I'm planning on running about 40psi fuel pressure at idle instead of 58-60. So that should help huh?
Running that setup on my Camaro with a 347 and E85 and it idles at 14.7 cleanly with a base fuel pressure of 54 psi. You should be able to get them to idle clean on gas by dropping the pressure a bit but decel will probably run rich regardless. You'll be missing some transient fuel tables on an 06 silverado operating system that would be beneficial but it's not too big of a deal.
BLK02WS6
08-30-2010, 07:52 PM
Working on a set of 95's with versafuelers and having trouble with them on gas. Going to try some more tomorrow...
BLK02WS6
08-31-2010, 06:28 PM
For those using EFILive and having problems - go to the EFILive forum and search for .cax files. Find the one for adding table B9021 - Min Pulsewidth... This did wonders for the one I was working on! was able to bring them right in to idle at 14.5:1
nicks2ndz
05-17-2011, 11:59 AM
does anyone have the injector data for these? voltage offsets, slopes, breakpoint....
mightyquickz28
05-31-2011, 05:11 PM
The surefire way to stop a thread is to ask for injector offsets. Lol.... You won't get told no or boo... it will just die....
Blown06
06-01-2011, 12:57 AM
pretty funny
mightyquickz28
06-01-2011, 07:01 AM
I contacted Jeff last night (designer of Acceleronics box) and asked about the offsets. Here's what he replied(keeping in mind, I have the 95# and an LT1)
I ran stock offset vs voltage values when I had the 95s in my LT1. I always recommend starting with the stock offset values for any ECU because low impedance injectors open about as quickly as stock injectors.
Generally speaking, offsets have a noticeable effect on idle and almost no effect on WOT, so that should guide your adjustments. The injector size constant will have less influence on idle than offset assuming you make small changes, e.g. changing the offset from 1.0 ms to 0.8 ms will make a noticeable AFR difference at idle and almost no difference at WOT.
Assuming you have the LT1 PCM, I'd start with 95 for the injector constant and stock offset vs voltage values. That should put you very close. I would not recommend using the Mototron values (assuming PCM4less changed the offsets) because those injectors are very lazy. You would probably be pig rich at idle with Mototron offsets.
