oil pressure wire...
Old 08-14-2010, 05:51 PM
Yellowbrother's Avatar
Default oil pressure wire...
will this wire from pcm run my autometer oil pressure gauge??? or should i proceed with the oil pressure sender that came with it??? i had already mounted that too just above the oil filter...i think the ls1 schematic says it's the tan wire from connector 220 i think...
Old 08-15-2010, 07:32 AM
Schitzo's Avatar
Generally oil pressure gauges are calibrated to a specific sender. Using the stock sender with your autometer gauge will give you false data. I would use the sender that came with the autometer gauge
Old 08-15-2010, 09:25 AM
thanks...i dont think it would work for me after jacking with the water temp gauge...my gauges are full sweep...
Quick Reply: oil pressure wire...
