Which suspension spring to buy for my fox body ls1?
I have Fox Body LS1 and I want suspension spring lower but not too much you know ls1 engine is lighter than the 5.0L engine. Which springs do u advice me to buy?
i think i have the aje 150 and they are the wrong ones with my iron block. i have to adjust them so there is just a little bit of tension on adjuster plate when its fully unloaded and my car sits higher then stock in the front.
Get a linear rate spring and cut them to where you want them. Or coilovers.
Depends on what you're going to do with the car. I like coilover setups because you can easily change out springs and springrates to suit your setup and what you're doing with the car.
