Broke down yesterday.. need help
My car completely died going up a hill yesterday.. it will not start at all now, had to get it towed
The fuel pump will prime and everything and it turns over but it is not starting.. i was wondering the best way to figure this out?
I'd really like some suggestions before i get into it
Thanks
Thanks
I had a coil do that to me. Ran awesome, then nothing, just like someone flicked a switch. I'm betting its a spark issue. If it was a fuel issue it would have started to lose power over a few seconds, spit and sputter, and then die out.
2 things you can check for spark:
1) http://shbox.com/1/coil_testing.jpg
and to make sure the coil is being told to fire (and it probably is and just not doing it):
2) http://shbox.com/1/4th_gen_tech2.html#opti_test
I soldered up all the crimped connections and (Ta-Da!), problem solved.
Hope it's that easy for you.
