How to wire up clutch pedal for auto swap?
How do I wire the clutch pedal up so that the computer always thinks it to the floor to start the car? Done a search but couldnt really find 100% answers.
Can someone give some more specific instructions, Last thing I need to finish. If you crank car it seems like it would fire right now witht thje clutch pedal to the floor and no wiring done.
Gingervitis Addict
Cut the 4 wires going to the clutch switch. The 2 wires that go to the brake pedal switch , just crimp/solder those 2 together. All they did was cut the cruise if you pushed in the clutch. The other 2 wires (that don't go to the brake pedal switch) extend both wires to the shifter. Connect each wire to 1 side of the NSS (Neutral Safety Switch). The NSS is now doing the same job as the clutch switch.
