Trying to get my car started w/o MAF
Old 08-15-2010, 10:26 PM
rockoosi1's Avatar
Default Trying to get my car started w/o MAF
I just finished putting a LQ4 into my 89 Camaro. The car will fire right up but dies one second later. I'm trying to locate a MAF but until then I wanted to get it started. I seem to remember people running these engines on stands and the back of trucks so I believe its possible. Can anybody help?
Old 08-15-2010, 10:29 PM
white84z's Avatar
It should run without a maf, sounds like you have a vats issue to me.
Old 08-15-2010, 11:34 PM
rockoosi1's Avatar
I use HPT, I went into the systems tab and changed the vats to none. Is there something else that I need to do? I'm using a PCM out of a 02 Camaro BTW.
Old 08-16-2010, 07:27 AM
rockoosi1's Avatar
Ok I found my problem. Although I had changed VATs to none I didn't turn off the DTCs. Did it this morning and she purs like a kitten. Thanks for the help!
Old 08-16-2010, 04:14 PM
aknovaman's Avatar
Need to set DTC code to MIL on first error for P0100, p0200, p0300 as well as setting VATS to none.
