questions regarding vats and bcm.
well i'm having all kinds of issues with my bcm module, vats is disable on my pcm tune, so i was thinking i could just get another bcm from a junk yard, and hope for it being in better working condition that my current one. so with what you said, this will work?
If the BCM is for the same vehicle and works good, you will be ok. You only need to marry your keys to the new BCM to re-enable VATS
