A/C Delete, what size belt?
From what I've seen it depends on which pulley you use (1LE, aftermarket, etc.). In my opinion, the best thing to do is to install the pulley, then measure the belt routing with a piece of string (or cloth tape measure), then buy 3 or 4 6-rib belts that are similar in length and see which one fits best, then return the others that don't fit.
I used the GM 1LE pulley and had to get a shorter belt. GM used 2 different sized pulleys on the A/C compressor, if you have the smaller pulley on your compressor you can use the stock belt. If you have the larger pulley like mine you need a belt that's 63.5".
